Forums >> Revit Building >> Technical Support >> Linked file materials 2016
Thu, Mar 3, 2016 at 1:01:53 PM | Linked file materials 2016
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Okay, embarassed to be asking this one--I just upgraded to 2016 and can't get materials to work right across linked files.
It used to be that linked files would inherit the material properties from the file they are linked into.  For example, changes made to Site - Grass in a site file should override the Site - Grass settings of a a building linked into it.
Correct? At least that's how it used to work, but I am now hitting my head against a wall. Have they hidden linked file materials somewhere and made them independant?
Edit: Even transfering project standards and bringing in the linked model's unique materials no longer permits me to override the link model's materials from the material manager of the master file.
Edited on: Thu, Mar 3, 2016 at 1:14:30 PM
Thu, Mar 3, 2016 at 2:27:11 PM | Linked file materials 2016
I have not checked this out yet in 2016 or even 15.   Old rule was materials of the same exact name - the host file rules and you can not assign new materials to a linked element ... but obviously, we could change the way that material looked.
Thu, Mar 3, 2016 at 2:36:44 PM | Linked file materials 2016
itsmyalterego
4 Stars: 16 Votes
Dang. That no longer seems to be the case.
I wish they didn't screw with the materials interface every. single. release.
Thu, Mar 3, 2016 at 3:43:15 PM | Linked file materials 2016
As far as I can see, you are correct.  Still testing.   This problem may be assets as well as material .....
Rendering Linked Materials in 2011.
Wed, Oct 12, 2011 at 2:10:46 PM
Materials and Linked Revit File into 3DS Max
Mon, Nov 18, 2013 at 12:27:44 PM
Materials not linking in linked file
Wed, Nov 26, 2008 at 9:09:04 AM
Navisworks 2016 Linked files not included when exporting to NWC file format
Wed, Apr 20, 2016 at 11:07:17 AM
Linked CAD files are not turning off
Tue, Nov 29, 2016 at 3:31:28 PM
14
Page generation time: 0.6720
