Forums >> Revit Building >> Technical Support >> Conditional toggle yes no formula
Thu, Mar 3, 2016 at 8:03:12 AM | Conditional toggle yes no formula
rgordon
I am trying to control 3 visibility states but I only want one toggle on at a time.  I know how to control 2 with a yes/no and a "not" condition, but I can't figure out how to control 3 yes/no so that only 1 is on at a time.  Any help would be greatly appreciated.
Thu, Mar 3, 2016 at 8:49:22 AM | Conditional toggle yes no formula
marmiketin1
4.5 Stars: 10 Votes
I have done this before using a control integer value. When the integer value = 1 then the first item is visible, when it is = 2 then the second item is visible and so fourth. I would also add a text parameter that staes "Toggle visibility by cycling integer between 1 and 3".
the visibilty parameters would look something like this.
integer = 1 (this would turn item 1 on when the integer is 1)
integer = 2
integer = 3
Thu, Mar 3, 2016 at 9:14:55 AM | Conditional toggle yes no formula
rgordon
That is similar to how I have had it set up, but it isn't the solution I am looking for.  Trying to make this dummy proof.  Thanks for the suggestion.
Thu, Mar 3, 2016 at 9:20:30 AM | Conditional toggle yes no formula
rgordon
Thu, Mar 3, 2016 at 11:43:05 AM | Conditional toggle yes no formula
marmiketin1
4.5 Stars: 10 Votes
As off current that is the simplest way to do it with just one control
conditional formatting yes no parameters
Tue, Oct 28, 2008 at 9:58:54 AM
Family types - conditional statement
Mon, Apr 18, 2011 at 3:59:50 PM
Schedule Parameter formula not showing up [ 1 2 ]
Thu, Oct 28, 2010 at 4:33:57 PM
23
Repeating Detail in Families
Tue, Aug 10, 2010 at 9:14:20 AM
Yes/No Conditional on No/Yes
Tue, Nov 11, 2008 at 12:21:06 PM
Page generation time: 0.3730
