Forums >> Revit Building >> Technical Support >> Roof Section Detail
Thu, Mar 3, 2016 at 6:04:23 AM | Can't see the details of the Roof in a detail section
SquareEdge
Hello Friends,
Why is it that when I create a section through the wall & roof at fine detail level (e.g. 1 1/2" = 1') - and it is set at "fine" for the visibility at detail level, I can see the layers of the wall (wood, gyproc, brick, membrane, etc.) but the roof shows absolutely no detail - just a blank thickness? Why can't I see the plywood sheathing, the shingles (if shingles were, let's say, 1/4" thick)?
Many thanks
SE
Edited on: Thu, Mar 3, 2016 at 6:05:47 AM
Thu, Mar 3, 2016 at 6:58:08 AM | Roof Section Detail
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Does your roof actually have layers to it?
Thu, Mar 3, 2016 at 9:09:50 AM | Roof Section Detail
SquareEdge
It's the standard roof from the default selection - "Basic Roof - Wood Rafter 8" - Asphalt Shingle - Insulated" - and when I click on the roof>Edit Type>Structure>Edit, then I get all the layers of the roof. The section works for the wall, but not the roof, that's what's so puzzling.
Thu, Mar 3, 2016 at 9:19:25 AM | Roof Section Detail
Something is wrong with your process because this does work.
Are you sure your section is actually cutting the roof?  Cut another section.
In VG, check your settings for your roof category.   It could be set to coarse for that view.
Detail Component visibility from wall section to detail callout view.
Thu, Oct 8, 2009 at 3:54:42 PM
callout annotation in section w/ coresponding section anno in plan
Mon, Sep 24, 2007 at 1:33:19 PM
plan detail callout in section
Fri, Mar 29, 2013 at 12:48:11 PM
14
detail section
Sun, Dec 19, 2010 at 6:22:27 PM
Detail References
Mon, Sep 24, 2012 at 8:26:51 AM
Page generation time: 1.0554
