Forums >> Revit Building >> Technical Support >> Window not cutting wall
Wed, Mar 2, 2016 at 11:52:06 AM | Window not cutting wall
LDMdrafting
Hi,
We have created a new window family, started from the generic window family, and it shows fine in 3d and elevation however it is not cutting the walls in plan view. The window is the full height of the wall so I don't think it is a view range issue. I have also check and all the vertical components at the top of the window are uncheck to show in plan/rcp. The wall and the window  are also set to the same phaswe.
We have searched the forums and can't find a solution. Hopefully someone here can help!
We are using Revit 2016.
Wed, Mar 2, 2016 at 1:37:04 PM | Window not cutting wall
Is this a stacked wall or multiple walls?  If so, look at the elevation and join the walls.
If that is not your problem, try increasing the wall thickness in the wall in the window family.
Wed, Mar 2, 2016 at 3:34:28 PM | Window not cutting wall
Bartholomew
5 Stars: 2 Votes
Do you have a plan region defined in that veiw? Does window display correctly in other walls? Have you tried replacing Opening with a Void Extrusion?
window not cutting joined roof
Mon, Mar 6, 2017 at 4:23:50 PM
Window not cutting furred wall
Tue, Feb 14, 2012 at 12:56:04 PM
Mon, Jan 10, 2011 at 6:43:59 AM
Floor Plan - Window Cutting Problem
Fri, Jan 7, 2011 at 4:16:59 PM
instance of window not cutting anything
Fri, Jul 13, 2007 at 12:05:31 PM
Page generation time: 1.0259
