13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Revit 2016 pauses to update during move command
11 Posts No Rating |
So in 8 years I've never had to start my own thread, always found it in search function... but here we go.
Autodesk Building Design Suite Premium 2016
16.0.1108.020160126_1600(x64)Update2 for R2
Usually this happens using the move command and I always use the move command via a keyboard shortcut:
I select at item (usually a wall) I initiate the move command, and halfway through the move, Revit decides to update and/or install something.
It takes a very long time. Then after the install everything seems to work just fine, except Revit seems to have reset itself and things like my custom keyboard shortcuts don't work anymore.
This has happened 4 or 5 times over the last couple of months of daily use.
Any ideas as to what is happening?
We had a similar problem and we uninstalled REX which seems to fix the problem. This was posted by Robert Bell on Autodesk site.
Thanks I will give that a try.
Can't relocate viewport with move command |
Mon, Dec 12, 2011 at 5:14:11 PM
What is the purpose of the dashed blue window when using the move command? |
Thu, Apr 2, 2015 at 1:18:06 PM
Revit 2016 Update 16.0.1063.0 |
Tue, Dec 8, 2015 at 8:58:19 AM
Massing appears when exporting from revit 2016 to navisworks 2016 |
Tue, Feb 2, 2016 at 11:28:30 AM
Revit 2016 |
Thu, Mar 31, 2016 at 11:00:08 AM
12
