Forums >> Revit Building >> Technical Support >> Transfering dwgs between titleblocks
Tue, Mar 1, 2016 at 5:38:55 AM | Transfering dwgs between titleblocks
timbuktu2
Hello,
I have to load a new titleblock template (non Autodesk) inorder to transfer scale (A0) dwgs into a scale A3 titleblock.
I notice that annotations placed on top of the existing dwg can be copy/pasted across  simply enough but anything drawn within the viewport can not.
Is there a way to transfer the dwg within the viewport in an Autodesk titleblock into another generic titleblock?
Tue, Mar 1, 2016 at 7:25:01 AM | Transfering dwgs between titleblocks
All views are easily moved sheet to sheet.  An even easier process is to swap the sheets.  In other words, open the sheet, click on the sheet and under type, pick your other titleblock.
For the method you are trying to do, if you had placed this CAD into a view and annotated it there, you would have no problems.
Tue, Mar 1, 2016 at 9:36:07 AM | Transfering dwgs between titleblocks
timbuktu2
Its all done - 28 dwgs in total.
Cheers.
Imported DWGs not exploding?
Tue, Feb 8, 2005 at 9:11:31 PM
model transfering to 3d studio
Wed, Aug 15, 2007 at 5:03:40 PM
Transfering Schedules & Phases (2009)
Wed, Oct 5, 2011 at 10:47:28 AM
TitleBlocks
Fri, Dec 8, 2006 at 8:08:02 AM
Titleblocks & Design Options
Mon, Dec 8, 2008 at 2:06:33 PM
Page generation time: 0.6656
