Forums >> Revit Structure >> Technical Support >> Wood Stud Wall Cut Patterns
Sat, Feb 27, 2016 at 2:12:35 AM | Wood Stud Wall Cut Patterns
minfante14
We model many multi-level, residential wood buildings.  I need to know if there's a way to denote out third type of wall's cut pattern.
First type is Wood Stud bearing wall which we assign a solid fill to the coarse fill pattern.
Second type Wood Stud shear wall which we assign a small diagonal fill to the coarse fill pattern.
Third is a combination Wood Stud Bearing and Shear Wall.  Is there a way to assign both a solid (shaded) fill and a diagonal line fill to the single family type?  Or using a filter override?
Thanks,
Marvin L Infante
BIM Technician
Denver Colorado
Sat, Feb 27, 2016 at 11:03:39 AM | Wood Stud Wall Cut Patterns
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I'm not exactly sure what the question is. A sketch goes a long way in describing this type of thing.
Mon, Feb 29, 2016 at 7:36:50 AM | Wood Stud Wall Cut Patterns
You can not assign two different fill patterns to a coarse wall.
Wood Stud wall
Thu, Feb 12, 2009 at 9:05:51 AM
Wall cut patterns
Fri, Jun 16, 2006 at 1:29:23 PM
Wood frame projects
Mon, Nov 14, 2016 at 3:41:23 PM
Wall Cut Pattern Plan View vs. Section
Fri, Jan 6, 2012 at 11:19:21 AM
How to create a 2x6 wood stud
Wed, Oct 16, 2013 at 2:24:57 PM
Page generation time: 0.8526
