Forums >> Revit Building >> Technical Support >> Keep .dwg Layers when exporting .rvt to .dwgPlease
Tue, Feb 23, 2016 at 11:43:46 PM | Keep .dwg Layers when exporting .rvt to .dwgPlease
SquareEdge
I am using Revit LT 2015 (Architecture). I get a .dwg file, insert it into my Revit file, then do a partial explode. At this point the lines still have their own names and colors. Then I draw on top of the lines, either following the lines or doing my own shapes.
Then I want to export the new combo .dwg/.rvt file back into a .dwg file for someone else's CAD software. The problem is that in the export, Revit flattens all the layers into one big layer and color, except for the Revit objects. But anything that was previously from the CAD file - ALL gets FLATTENED out! The guy at the other end (who is receiving this .dwg file) is NOT happy about what's happening here!
Please tell me how to keep all the CAD layers (that were there from the original import) when I export from .rvt back into .dwg.
Many thanks!
J
Wed, Feb 24, 2016 at 9:27:59 AM | Keep .dwg Layers when exporting .rvt to .dwgPlease
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
You can preset how Revit exports its objects into DWG through the use of the following:
R Button - Export - Options - Export Setups DWG/DXF.
In the window that opens, you can use preset layer conversions from the AIA/British Standards etc or you can create your own.
Be mindful that Revit is not AutoCAD, it creates content differently using intelligent objects not dumb lines. So trying to convert some of these objects into a particular layer is impossible (unless you want to do it for them in AutoCAD).
My approach to working with users who draw in AutoCAD differs and this approach is something you may need to consider as well. Firstly, you use Revit. It is your preferred software. If you need to do any post-export work, you are in effect doing the work for someone outside of your company and wasting your bosses money.
I limit my post export work to auditing, purging and zooming to extents. I leave the rest up to the consultant, who's choice to use an out-dated software is theirs alone.
Exported DWG content to be issued shall only be saved in the drawing issued folder with the DWG’s named the same way as the PDFs. (See section 16.1)
Imported layers still active when exporting
Fri, Feb 26, 2010 at 8:44:40 AM
Exporting Revit 2009 (.rvt) to AutoCAD (.dwg)
Mon, Jul 13, 2009 at 3:55:27 PM
exporting to dwg
Wed, Aug 18, 2010 at 5:10:21 AM
DWG export: room tags to different layers
Tue, Oct 7, 2014 at 7:27:53 AM
Keep layer names when exporting to DWG
Mon, May 13, 2013 at 7:48:10 AM
Page generation time: 0.1739
