Forums >> General Discussion >> Revit Project Management >> Export IFC from Revit
Mon, Feb 22, 2016 at 4:50:56 AM | Export IFC from Revit
simon1688
I've exported an IFC file ticking the split walls and columns by level option however when I open the IFC file some columns are split level by level and some are still showing full height through multiple levels, any ideas anyone?
Revit 2014 user
Mon, Feb 22, 2016 at 2:50:40 PM | Export IFC from Revit
onej6
are the uncut collums from the same family? I've had this problem with a 'collum' made as a floor based generic model.
Mon, Feb 22, 2016 at 3:03:56 PM | Export IFC from Revit
simon1688
Yes it's the same family and type
Revit 2014 user
Mon, Feb 22, 2016 at 3:21:16 PM | Export IFC from Revit
Although I'm not familiar with these problems because we don't do IFC, I think there is more to the question asked by onej6.   You say they are the same family but are they all placed the same way?   Are some one story columns and some multistory columns?   If they are different to begin with then that might explain this.
Sat, Mar 5, 2016 at 3:39:57 AM | Export IFC from Revit
simon1688
Found the solution, I needed to tick the building storey parameter
Revit 2014 user
Revit MEP IFC Export - Objects not detalied
Wed, Jul 2, 2014 at 8:08:29 AM
Revit Family Export to IFC
Fri, Nov 29, 2013 at 4:29:41 PM
IFC export: Gross Area
Fri, May 29, 2009 at 3:01:19 AM
IFC Export - Unrecoverable Error - Aborted
Wed, Feb 26, 2014 at 8:15:09 AM
IFC export
Wed, Oct 28, 2009 at 12:02:48 PM
Page generation time: 1.3800
