Forums >> Revit Building >> Technical Support >> tiling windows
Wed, Apr 5, 2006 at 3:57:29 PM | tiling windows
gdoorn
1 Stars: 1 Votes
is there a way to have the windows tile side by side as opposed to on top of each other when you tile the open windows? (this is related to a dual monitor set up and spending a couple weeks detailing out wall sections.
Wed, Apr 5, 2006 at 4:14:24 PM | RE: tiling windows
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Don't think so, window tiling is automatic based on how many views you have open. You could manually rearrange window sizes and positions though...
Wed, Apr 5, 2006 at 4:47:15 PM | RE: tiling windows
gdoorn
1 Stars: 1 Votes
yeah, thats what i have been doing. what can i say? i am spoiled and lazy.
Thu, Jul 17, 2008 at 10:48:11 AM | tiling windows
AbelGoddard
AbelGoddard Avatar
Bump to this.
Can we put this on a wishlist? It is a MAJOR pain in the rear (and a dumb design, IMNSHO) to have the tiling of 3 windows place the full length window on the right. But, barring that little change (swap the 2 for 1 left/right), I would much prefer to be able to customize my tiling and save the settings based on how many windows are open.
Basically, give me God-like control over the tiling! And do it yesterday, if you don't mind.
Helping you Be Able to be the person you want to be!
Sign up for my free newsletter, Being Able, at http://www.AbelGoddard.com
Tue, Mar 30, 2010 at 11:45:33 AM | tiling windows
turboash
turboash Avatar
Super Bump!
Still no Tile Vertically option with Revit 2010... which is BS considering I assume the majority of users run dual monitors.  I run Revit stretched across dual 24" widescreens, and needless to say WT is completely useless.  I would love a shortcut to tile vertically instead of having to do it manually.  Completely unacceptable Autodesk!
End rant.
Wed, Oct 14, 2015 at 12:23:25 PM | tiling windows
aricbouwers
ultra bump!
Still no setting in Revit 2015... oh well, we will just have to accept that Autodesk likes designing gimicks for newer releases instead of perfecting workflow
Wed, Oct 14, 2015 at 1:15:54 PM | tiling windows
We recommend that you always read the similar threads like the one that points to this app:
https://apps.autodesk.com/RVT/en/Detail/Index?id=appstore.exchange.autodesk.com%3apalladioxbimwindowslayout%3aen
Tiling windows
Thu, Jan 30, 2014 at 2:20:42 PM
Adjust hatching to follow brick courses or tiling for tiling layouts
Tue, Aug 5, 2008 at 10:14:12 AM
Tiling Layout
Wed, Oct 6, 2004 at 1:28:49 AM
Placing filled regions for tiling in bathrooms
Fri, Jun 10, 2005 at 10:35:11 AM
Tiling Seamless Texture Images
Tue, Oct 12, 2004 at 8:08:15 PM
Page generation time: 4.0112
