13 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Creating an angled cellar door
Hi
Anyone tried to make an angled cellar door? I tried to rotate a wall. I 've tried a trianglar mass. Need some outside the box thinking because ifI remember right walls in revit like to go striaght up and down. I thought that I might be able to make the angle of a triangluar mass into a wall and drop an door in that butno luck.
Thank you
Kirk
Not following you. "Angled cellar door?" Regarding walls: they can be non-perpendicular to the floor. Wall By Face. If you want a pendendicular door in a non-perpendicular wall, use a void extrusion, instead of an Opening, and make it deep enough to cut an entire opening through the angled wall.
Edited on: Thu, Feb 18, 2016 at 6:56:36 PM
Barrel Vaulted Cellar |
Fri, Mar 12, 2010 at 12:12:03 PM
Revit 2011, Creating a wall with an angled end. |
Wed, Feb 7, 2018 at 10:55:53 AM
"Cant Make Door" Warning |
Thu, Oct 23, 2014 at 2:45:09 PM
angled roof / wall |
Wed, Feb 20, 2008 at 9:30:54 AM
Angled Walls in Revit |
Mon, Jan 12, 2015 at 8:48:26 AM
