10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Face Based Component - Default Load Settings
4 Posts No Rating |
So I'm making a new plumbing fixture component to be face based (for grouping issues..) and everything is working well except when you load the family into a project the default placement plane is set "Place on Vertical Face". Is it possible to change it to either "Place on Face" or "Place on Workplane"?
Many thanks in advance
4 Posts No Rating |
EDIT: Found a pretty simple workaround...start with the OTB Domestic 3D Toilet and build from that, then delete the unnecessary elements that you don't need.
However, if anyone has insight on the placement plane default issue, I'd love to hear about it.
-t
Converting Ceiling Based families to Face Based Families |
Tue, Jun 12, 2018 at 7:13:41 PM
Face Based Component [Wall Overlapping Issues] |
Thu, Mar 27, 2014 at 1:06:24 PM
Tagging Default Elevation Parameter for Face-Based Families |
Wed, Aug 13, 2014 at 8:57:26 AM
Face based components in legends |
Wed, Mar 9, 2011 at 11:20:37 AM
Insertion point for wall based component |
Mon, Apr 3, 2006 at 5:18:30 PM
