Forums >> Revit Building >> Technical Support >> Doors won't cut
Sun, Feb 14, 2016 at 6:03:12 PM | Doors won't cut
GLKIRK
Can I bother someone to help me figure why the doors won;t cut through the one course of CMUs on this wall?
I use 2013
Thanks!
Gary
Sun, Feb 14, 2016 at 9:17:00 PM | Doors won't cut
Bartholomew
5 Stars: 2 Votes
Post the rvt. The pdf tells nothing.
Sun, Feb 14, 2016 at 10:09:41 PM | Doors won't cut
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Try cutting and pasting them back aligned to the same place.
Mon, Feb 15, 2016 at 1:04:24 AM | Doors won't cut
Bartholomew
5 Stars: 2 Votes
Oh, so we’re just guessing here? Well then, I suppose my suggestion would be to use the Cut Geometry tool to join the two walls together.
Edit: You sure the door isn't cutting? From the image you posted it looks like it did. The door looks like it has mirrored inset panels, or it has hollow panels and the interior right wall of your garage has the same finish as your exterior walls.
Edited on: Mon, Feb 15, 2016 at 1:21:37 AM
Mon, Feb 15, 2016 at 4:31:44 AM | Doors won't cut
GLKIRK
Thanks for the thoughts.
Funny thing, I came back to it later and all is fine, cut just fine!
This has happened before.
How would I send a RVT file? I thought it was way too big?
Thanks again
Mon, Feb 15, 2016 at 11:25:43 AM | Doors won't cut
Bartholomew
5 Stars: 2 Votes
Just reduce the content of the rfa to meet the size RevitCity allows for uploads. People post rfa's all the time. In your case, you could have cut and pasted the offending door and wall into a new project, and uploaded that.
Host Sweep won't cut thru Windows
Sun, Nov 9, 2008 at 6:29:55 AM
Extrusion won't cut
Fri, Jun 23, 2017 at 12:42:31 PM
Voids won't cut wall
Mon, Aug 25, 2008 at 12:16:36 PM
Hiding Demo'd Garage Doors
Wed, Aug 10, 2005 at 8:02:23 PM
Void Won't Cut Extrusion
Wed, Feb 13, 2013 at 11:04:26 AM
Page generation time: 3.9123
