Forums >> Community >> Newbies >> Creating wall elements with extensions
Sun, Feb 14, 2016 at 11:59:46 AM | Creating wall elements with extensions
Sangarrb
Hi, I am quite new in revit and maybe someone could direct me how to make my wall elements with extension. I added pdf file for better understanding. I know how to get upper extension. I can get it by creating a stack wall type. The question remains how to get the extension on sides as well? Also I would require to change the length and thickness of the extension and the best way is to have grips in there. Should I create a family instead of wall type? But then I cannot describe my wall layers? How would you do this work? Thank you already in advance.
Sun, Feb 14, 2016 at 3:58:09 PM | Creating wall elements with extensions
Bartholomew
5 Stars: 2 Votes
Could you please clarify the orientations of the 2 views shown in your PDF. Perhaps, a reference view showing where the section cut arrows are placed in relationship to the wall, would help explain what we are looking at.
Mon, Feb 15, 2016 at 8:24:26 AM | Creating wall elements with extensions
For the vertical "extension" - Watch the video here to learn how to modify your wall - I would not use a stacked wall.  You qould also use a void sweep in the wall definition or in place.
For the "end extension" as you call it, use a vertcal void sweep or create a face based void family to cut your wall.
Mon, Feb 15, 2016 at 3:32:40 PM | Creating wall elements with extensions
Sangarrb
Thank you very much for the link and response. I got the "end extrusion" done with selecting under component -> model in place and there void form extrusion and then using cut tool. I will try face based void family as well (not sure how to do this exactly at the moment, but now I know what am looking for. Thanks again for directions.
wall extensions not working
Wed, Feb 17, 2010 at 6:16:11 PM
14
Handrail Extensions in 2013 - Where is it?
Sun, Jul 12, 2015 at 11:54:18 PM
Revit Extensions Tuitorial
Wed, Oct 14, 2009 at 8:58:21 PM
need some help on extending wall layers?
Mon, Jun 1, 2009 at 1:33:27 PM
Modified wall layers (Sheating) need cutouts for openings and extensions
Tue, Sep 23, 2014 at 8:45:35 AM
Page generation time: 6.7296
