Forums >> Revit Systems >> Tips & Tricks >> Heating filters
Fri, Feb 12, 2016 at 5:14:42 AM | Heating filters
Christophski
Hi,
I'm pretty new to Revit (2014), and im trying to get some heating filters up and running to apply to a template.
I have LTHW F and LTHW R as system types, and all heating pipes are on a heating workset. the F and R are to be different colours, so i need 2 filters.
So i set a filter to be coloured by a workset and that works fine. I had hoped to add another rule to the filter saying: 'by type-contains: 'LTHW F'. but the 'contains' isn't there, only 'equals' and it demands i add in a formula.
Im trying to avoid making more worksets than needed, so is there a way to make 'contains' appear or failing that, is there a better way to tell the filters i want F and R to be different?
cheers.
Fri, Feb 12, 2016 at 11:03:41 AM | Heating filters
Christophski
Fixed it, the option appears after unchecking 'piping systems' in the categories
heating
Tue, Apr 12, 2011 at 8:18:31 AM
Switch off Pipe systems in Revit MEP
Mon, Aug 17, 2015 at 8:33:14 AM
How to: Infloor heating tubing
Wed, Mar 7, 2012 at 1:36:00 PM
11
heating & cooling Report
Tue, Nov 12, 2013 at 4:32:08 PM
Heating & cooling calc
Wed, Nov 13, 2013 at 9:56:26 PM
Page generation time: 0.0315
