18 Users Online (16 Members):
Forums >> Revit Structure >> Technical Support >> Creating drop panels to the underside of a sloped floor slab
28 Posts No Rating |
I'm using revit 2015. I need to add 12'-0"x 12'-0" x 6" deep drop panels to a 9" floor slab. The problem is the floor slab is sloped and so is the underside of the floor slab. Is there an easier way to slope the drop panels other than using the "Modify Sub Elements" command? It's a huge project with multiple floor slabs of different slopes.
What do you mean by "dropped panels" ? Do you mean a floor depression or a thickened area?
I use a face based void family to create floor depressions. You could use a similar family to thicken an area by applying it to the bottom face of the floor.
WWHub,
The drop panel is essentially a 6"thinken slab under the main 9" thick slab. If the 9" floor slab was perfectly flat you just create another 12'x12' floor slab that's 6" thick and adjust the "Height Offset from Level" so the slab is -9" below the main floor slab.
Here is a sloping slab with a face based family like I suggested.
Drop Slab |
Wed, Jul 9, 2008 at 12:57:15 AM
How to get wall to run to underside sofit/underside of slab |
Fri, Jul 6, 2012 at 11:54:22 AM
creating a sloped floor |
Thu, Jul 15, 2010 at 5:47:03 PM
Slab Edges on Sloped Floors |
Wed, Aug 12, 2009 at 12:37:28 PM
need HELP with creating a light shelf! |
Thu, Apr 19, 2007 at 7:15:59 AM
