22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> how to create revit family from cad 3d drawing
6 Posts No Rating |
halo!
if i draw a 3d object in cad (dwg), how do i turn it into a revit family (rfa) drawing?
please advise step by step
thanks!
step by step
Step One. Don't
best regards
coreed,aia
Take a look at the "How to grow your family..." tutorial on this site.
I wouldn't start a family from scratch using AutoCAD, but if the AutoCAD geometry exists then it is perfectly acceptable to re-use it in a non-parametric Revit family. Most of the Revit web library from Autodesk itself uses this technique.
Tom
I received some CAD 3D furniture from a furniture specifier and am trying to make it usable in Revit. Unfortunately when i just import it as a CAD drawing it appears solid black in plan becuase of all of the contour lines. Is there a way to convert it to a Revit family or Sketch-up file?
If you created the family but are only having problems with too many contour lines then just put some symbolic lines in plan and turn the 3-d object off in plan. This is most likely the fastest solution but not the sexiest.
Xclip an inported CAD image in Revit |
Wed, Aug 4, 2010 at 2:26:12 PM
CAD import to Revit |
Mon, Dec 13, 2010 at 3:34:54 PM
REVIT / CAD Coordinates |
Wed, Jul 2, 2014 at 9:55:19 AM
export to CAD from isolated view |
Fri, Aug 1, 2008 at 9:25:47 AM
Autocad 3d drawing in to Revit? |
Sun, Jun 5, 2005 at 8:01:16 PM
