Forums >> Revit Building >> Technical Support >> Section cut_ wall sweep causes materials to disapear
Tue, Feb 2, 2016 at 12:28:25 PM | Section cut_ wall sweep causes materials to disapear
LIBBY
So I'm having an odd issue.
When I add a wall sweep as a sill block it causes the
different materials of my wall in section to disapear.(see attached)
I've tried to adjust the insertion point from the top to bottom.
Right now it is set to the top corner/face of wall.
Has anyone else ever run across this problem?
Is there some fix that I'm missing? or is my wall sweep
corrupt? it does have a detail component in it that has a void
so that it shows correctly in sections and details.
even with that removed it still makes the materials disapear Sad
Help
Tue, Feb 2, 2016 at 12:44:28 PM | Section cut_ wall sweep causes materials to disapear
There is no such thing as a 'void' in a detail component.  Details are strickly 2D.   Did you meana  'masking region' is in your detail component?  If so, then perhaps that masking region is a problem.
Why do you have a detail component in this sweep?
Void Sweep Through Wall and Section
Fri, Mar 11, 2011 at 7:17:59 AM
Column grid lines disapear in one section view.
Thu, Aug 2, 2007 at 5:00:17 PM
Wall sweep won't trim
Tue, Apr 25, 2017 at 2:07:17 PM
Sweep Thickness Not Showing in Section
Wed, Nov 3, 2010 at 9:42:01 AM
Topografy Hatch disapear under Pad
Sat, Jun 22, 2013 at 5:51:27 AM
Page generation time: 0.8084
