Forums >> Revit Building >> Technical Support >> Revit 2014 Export Sheets or Save to new file
Thu, Jan 28, 2016 at 10:34:08 AM | Revit 2014 Export Sheets or Save to new file
WinterRiver1971
Ok lets try this one again.
I have a Revit project that has over 400 sheets each with a view which details a construction detail. The project was created as a library of typical and non typical details.
I want to export or save to new individual file all the sheets into seperate files in a Master format family folder on my desktop. The reason for this is so I can hand out seperate rfa details as per the MF number not as one project with all the details  at once.
Saving or exporting each file one at a time is tedious. Is there a way I can export the entire set of sheets at once in separate files
Thu, Jan 28, 2016 at 11:21:21 AM | Revit 2014 Export Sheets or Save to new file
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You can export each sheet as a .dwg but there is not way to export revit as revit.
Renderings will not save to project or export
Sat, Nov 29, 2008 at 4:41:39 PM
Revit 2014 Sve to New File
Mon, Jan 11, 2016 at 11:21:24 AM
Export 3D view to new revit file
Fri, Feb 24, 2012 at 11:36:49 AM
Help! How to save a template file as an rvt file?
Wed, Aug 20, 2008 at 11:27:01 PM
Titleblock resized after export
Fri, Feb 7, 2014 at 8:32:22 AM
Page generation time: 2.4069
