18 Users Online (16 Members):
Forums >> Revit Structure >> Technical Support >> Openings
2 Posts No Rating |
May I ask:
The "Cased opening" family does not seem to work in my 2013 version.
How should a person draw a cased opening?
Is there a way to make the door only disappear? or other?
Thank you very much!
Best solution - find one that does work. Why doesn't yours work.
To quickly create a 'cased opening' family:
- open a single flush door family,
- do a save as xxxx cased opening
- delete the door leaf model element
- delete the door panel and door swing annotation lines
- delete the threshold lines if any
- save then load into your project.
Copy Monitor Shaft Openings |
Thu, Oct 21, 2010 at 8:16:14 PM
Curved wall openings |
Fri, Oct 15, 2010 at 12:42:11 AM
Openings in different phases |
Tue, Apr 20, 2021 at 7:23:42 PM
Openings--how do you control constraints? |
Thu, Jun 11, 2009 at 1:57:49 PM
face based shapes with openings |
Mon, Mar 9, 2009 at 3:10:10 PM
