21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> Sections not visible in some views
Hi,
I'm using Revit MEP 2015 and I have opened an arch model and I"m trying to cut a section in the arch model but it keeps telling me that none of the created elements are visible in the RCP plan that I'm tying to cut the section in. I have checked VG and sections are checked to be on and made sure there are no view templates applied. There must be a setting for the sections to be visible. My work around for now is to create a new view in the arch model and then it will let me cut a section and show up, can anyone enlighten me on this. I have tried just cutting sections in other arch models before and seem to run into this issue a bunch. I have messed with the hide at scales coarser than 1/8" setting and still can't seem to make this work even if I set it to 400'. Maybe I"m not understanding the setting on this but I'm stumped for now. Any help on this would be appreciated.
Revit has a do not show if view is coarser than setting. Change the view scale to a larger setting and see if the section cuts show.
WWhub,
I have increased the scale of the view and I'm still not seeing the sections in the view.
building sections visible but detail view sections NOT visible on all drawings?? |
Tue, May 27, 2008 at 12:50:20 PM
Sections lines not visible in certain plan views. |
Wed, Dec 14, 2005 at 11:30:15 PM
Linked Structural model not visible is certain rotated section views |
Tue, Dec 22, 2015 at 2:27:12 PM
11
3D objects not visible in sections but visible in plan & 3D? |
Wed, Nov 12, 2014 at 10:58:40 AM
Sections, different level/views |
Sat, Aug 5, 2017 at 7:34:44 AM
