12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Overwriting an element
208 Posts No Rating |
Hi all,
One of the projects we are working on refuses to display the option box asking if you would like to overwrite the existing element with the one you are loading into your project.
As a result we cannot update any model parts within the project.
What may be causing this?
cadjockey
Hi all,
I am hoping someone has a solution to my problem.
It seems the challenge I have described above is only present in one particular project. All other projects will update familes brought into them without a problem.
The problem child project simply will not give me the option to overwrite an existing family and as such does not update the family element.
Is it a preference setting or something like that that needs to be switched on/off?
I have tried loading the family from the project via 'File/Load from family' and also direct from the family using the 'Load into project' facility. No joy!
cadjockey
Overwriting Dimension with Text |
Thu, Jan 11, 2007 at 11:13:56 AM
Deleting an element within 3D environment doesn't delete the element from the 2D |
Tue, Jun 26, 2012 at 1:35:59 PM
switching element type to curtain element error |
Wed, Nov 16, 2011 at 1:37:03 PM
Keeping an Element Keynote from changing? |
Mon, Apr 15, 2013 at 12:14:43 PM
A fatal error loading family into project overwriting existing |
Mon, Jun 22, 2015 at 8:03:38 AM
