Forums >> Revit Structure >> Technical Support >> How to model a non-typical length stair tread for the top tread
Mon, Jan 25, 2016 at 12:20:14 PM | How to model a non-typical length stair tread for the top tread
Sparky1985
I am trying to become effiecent with the stair modeling tools in Revit. I have a wood structure that requires the top tread to be longer than 11". Using either of the methods or which is the better of the two to accomplish a task like this. I am using an open stringer 7" riser w/ 11" treads.
I have found that using the stair by component works well because I can give the stairs an extra riser, deselect the end with riser option so that I have the last tread at the finish floor level where I need it to be. I just can't figure out how to make the last tread longer to connect to the existing beam (12 1/4").
Thanks for your help,
Mon, Jan 25, 2016 at 12:44:40 PM | How to model a non-typical length stair tread for the top tread
Why not end with riser and model in place last tread?
Mon, Jan 25, 2016 at 1:11:13 PM | How to model a non-typical length stair tread for the top tread
Sparky1985
I had thought about that, I was just curious if there was a way to keep the stairs a complete unit. If I go this route it creates an issue with the stringer connection also. I have attached a photo for reference.
Thanks,
Edited on: Mon, Jan 25, 2016 at 1:52:42 PM
Mon, Jan 25, 2016 at 1:40:59 PM | How to model a non-typical length stair tread for the top tread
What does that have to do with this?  Ending with a riser and in-place tread should work.
Mon, Jan 25, 2016 at 1:55:19 PM | How to model a non-typical length stair tread for the top tread
Sparky1985
sorry, I misread the reply above.
2015 use baluster per tread on stair (with no top rail?)
Thu, Sep 3, 2015 at 4:50:57 PM
Custom Stair Tread Profile vs. Default Tread Profile
Tue, Apr 30, 2019 at 2:28:08 PM
Baluster extensions at bottom of stair runs.
Fri, May 15, 2015 at 9:53:56 PM
Baluster per tread on curved stair
Thu, Apr 4, 2013 at 2:18:52 PM
Stair Riser/Tread Number in Multistory Stairs
Tue, Sep 13, 2016 at 9:47:54 AM
Page generation time: 2.6752
