Forums >> Revit Building >> Technical Support >> material transparency in elevation views
Fri, Jan 22, 2016 at 10:21:08 AM | material transparency in elevation views
sgray05
In doing some research, I discovered some past forum chains that discuss this issue, however it did not appear (as of a few years ago) that there was a resolution.
I am trying to get a specific material to appear as transparent in elevational views. The properties of the material are set as having a transparency and show as such in 3D views, but for elevations, they appear as non-transparent. I know that I can override the properties of these elements by selecting the object and perform and override graphics and change the transparency, but this only affects that perticular view.
Is there a command that will do this project wide?
I am using this approach for indicating a fence that will have a large degree of transparency while also providing a appreance of pickets or chainlink. (creating a wall type that has the desired material pattern applied)
Is there a better way to construct a fence that would provide these results other than the way I am proceeding?
or am I stuck to having to go through each view and perform the override to each element?
Thanks
Thu, Mar 31, 2016 at 11:33:41 AM | material transparency in elevation views
sreed2
I've always adjusted the views individually. But, you can adjust just one elevation view, create a view template > from current view and apply it to the rest of the elevations that have the fence.
Fri, Apr 1, 2016 at 3:17:41 PM | material transparency in elevation views
marmiketin1
4.5 Stars: 10 Votes
I havent yet done this myself but i had the idea the other day of using a curtain wall system to model a fence. you could use the mullions as the posts and horizontal members and then create a custom curtain panel that is either a pattern on an extrusion or actual model linework. Might be a bit more system heavy if you used model lines.
transparency in elevation views?
Tue, Feb 28, 2006 at 4:25:30 AM
Glass transparency in elevation view & split face command
Sat, Mar 22, 2008 at 12:01:35 AM
controlling transparency / visibility
Wed, Oct 24, 2007 at 4:59:24 PM
Elevation Transparency
Wed, Sep 12, 2007 at 8:52:05 PM
Basic Wall as Curtain Wall panel transparency incorrect.
Wed, Nov 23, 2011 at 9:37:16 PM
Page generation time: 0.7570
