Forums >> Revit Building >> Technical Support >> Wall Finishes Aligned to Door Trim
Thu, Jan 21, 2016 at 3:49:32 PM | Wall Finishes Aligned to Door Trim
joglo
How can I get a wall finish (in this case, tile) to butt up against the door trim? In other words, I want the door trim to wrap around the door trim and not the tile. It would be great if this could be automatic.
Thu, Jan 21, 2016 at 4:08:48 PM | Wall Finishes Aligned to Door Trim
This is something that I never worry about because it can be taken care of at the detail level where the model door frame is turned off.  No matter - the solution is a little complicated.   Look at the attached image.  Here is what I did.
  • Your door fame needs to be smaller because you don't want the tile under the frame. ... correctly.   We typically never add tile to the wall description because tile is never full height and often has base - main field and possibly a bullnose top.   So we use a thin wall (usually a stacked wall because of above.)  This all is aligned with the host wall and then joined so that the host wall doors/windows/acessories properly cut the tile.  This means the door frame will now properly size and place.
  • If you use a normal door, the tile will only cut at the opening cut.   That means it extends into the frame area.   To solve this, I added some masking regions to the door frame family.   You could also use a void cut in lieu of the stock opening cut.
Door Trim Parameters
Fri, Sep 11, 2009 at 12:52:57 AM
Trim and frame does not adjuts to wall as expected
Wed, Mar 1, 2006 at 12:22:56 PM
Stone wall covers door and window trim?
Thu, Jan 3, 2008 at 8:50:32 AM
Wall sweeps cover door trim
Wed, May 23, 2007 at 5:39:11 PM
Aligned dimensions for centering curtain wall door
Fri, Dec 23, 2011 at 6:26:40 AM
Page generation time: 0.5840
