Forums >> Revit Structure >> Technical Support >> Custom Linetype Not Showing When Inside of Another Family?
Thu, Jan 21, 2016 at 1:54:51 PM | Custom Linetype Not Showing When Inside of Another Family?
jcgentry94
Hello all, I'm using Revit 2015.
I've created a custom linetype with text that we use to represent certain reinforcing elements (rebar, mesh, etc.) It works fine whenever I insert it straight into a project. I want this custom "line" to be a part of the rebar family that I've created. While looking at and testing the rebar family by flexing the parameters, the line shows with no problems. But, whenever I insert the "rebar" family into another project, it just shows the line, with no text. Why isn't it showing that text as well? I've included a couple images with the issue.
Thu, Jan 21, 2016 at 2:50:44 PM | Custom Linetype Not Showing When Inside of Another Family?
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
http://www.revitcity.com/forums.php?action=viewthread&thread_id=5324
Mon, Jan 25, 2016 at 8:21:45 AM | Custom Linetype Not Showing When Inside of Another Family?
jcgentry94
That link seems to just show how to make the line, which I've already done. The issue comes whenever I try to nest that linetype family into another family.
Mon, Jan 25, 2016 at 9:11:55 AM | Custom Linetype Not Showing When Inside of Another Family?
I tested this and could not get it to work either.   I think it is because this line based element is using an array.
How to add new linetype to family
Fri, Jan 3, 2014 at 10:01:49 AM
Select all of one linetype in a view?
Tue, Jan 10, 2012 at 3:31:14 PM
spot elevation & custom pipe tag
Mon, Mar 24, 2014 at 10:29:52 AM
Handy Linetype
Sun, May 7, 2006 at 8:14:27 AM
Showing objects in higher levels in hidden linetype
Tue, Feb 21, 2012 at 7:10:07 AM
Page generation time: 0.7509
