Forums >> Revit Building >> Technical Support >> Plotting to PDF format
Thu, Jan 21, 2016 at 1:52:29 PM | Plotting to PDF format
Fifthdayllc2014
Have noticed that if i turn shadows on for elevations  and then plot them to a pdf format, the plot is screened.  By simiply removing the shadow feature, the plot in not screened.  In the Revit screen all is normal. Any suggestions?
Thu, Jan 21, 2016 at 3:08:26 PM | Plotting to PDF format
From YOUR HELP:
Revit automatically uses raster processing for a view if any of the following are true:
  • The view uses shading, shadows, gradients, or sketchy lines.
  • The view is rendered.
  • The view contains an image.
  • The view uses point clouds.
  • The view contains a decal.
You are probably seeing a raster print - not a screened print.
Plotting PDF's
Tue, Jul 21, 2009 at 4:18:05 PM
Printing files to PDF format in Revit 2008 Building
Fri, May 30, 2008 at 1:03:04 PM
RVT 9.1 - plotting as PDF changes lines to halftone
Tue, Jul 24, 2007 at 3:54:18 PM
plotting problem
Wed, Dec 22, 2004 at 3:44:51 PM
Export Schedule into PDF format
Wed, Sep 2, 2009 at 12:08:18 PM
Page generation time: 4.6320
