Forums >> Revit Building >> Technical Support >> problem w/ solid blend command - twisted form
Tue, Apr 4, 2006 at 3:29:19 PM | problem w/ solid blend command - twisted form
DigEms
I am trying to make blended solid w/ two egglike shapes, and instead of blending it uniformly, it twists the form. I went under vertex connect and saw that the vertexes aren't aligned correctly, causing the twist. It will not let me change where the vertexes connect, though. Is there any way to fix this? I included the file I'm working with. Thanks for any insight.
wall solid blend
Tue, Aug 18, 2009 at 3:56:25 PM
Create form tool for components other than mass - Revit Architecture 2012
Mon, Oct 20, 2014 at 4:15:58 PM
angled walls
Thu, Jun 25, 2009 at 2:06:18 AM
void form and cuttng void form
Fri, Jul 9, 2010 at 12:39:02 PM
twisted/slope/curve roof
Thu, Oct 19, 2006 at 7:26:04 PM
Page generation time: 1.3915
