Forums >> Revit Building >> Technical Support >> Area of Generic 4 Point Adaptive Panel Family
Wed, Jan 20, 2016 at 9:41:10 AM | Area of Generic 4 Point Adaptive Panel Family
Toteaux
Hi guys,
Using Revit 2014, I'm having an issue with being able to generate and schedule the area of a generic model 4pt adaptive component in the project environment. I have applied a formula for the area in the family which seems to work ok when flexed, however when I load this into a project and place the component, it no longer appears to calculate the correct area of the panel. Instead, the area parameter is 'static' and just shows the value from the family when it was loaded.
The family rfa is attached.
Regards
D
Wed, Jan 20, 2016 at 9:54:14 AM | Area of Generic 4 Point Adaptive Panel Family
How can you do this?  A four point adaptive component can be rectangular or trapezoidal when placed in a project.
Wed, Jan 20, 2016 at 9:56:14 AM | Area of Generic 4 Point Adaptive Panel Family
If a material is placed with the component, you should be able to schedule that.
Wed, Jan 20, 2016 at 10:31:29 AM | Area of Generic 4 Point Adaptive Panel Family
Toteaux
The formula for the Area in the family is for a genral quadrilateral, so it can accurately calculate the area of any four sided shape (so long as it's kept planar).
Yes the material and schedule method does work, but I'm curious as to whether it can be one th other way. Also, I tried this with a Curtain Panel Pattern Based family, and it worked fine in both family and project. However Revit automatically gives an area for this anyway, just not with generic models.
So I've just changed the Family Category from generic model to curtain panel and now it's giving me an area without the need for a formula.
(Sorry if this doesn't make much sense but I working this out and replying in tandem so it's kind of a real-time response).
Thanks WWHub for the help!
Regards
D
3D Multi-planar Spline Sweep with Adaptive Family
Fri, Mar 21, 2014 at 3:23:47 PM
Generic Error - Curtain Panel Family - uh...What?
Tue, Oct 27, 2015 at 7:44:30 PM
Adaptive component - Bracket
Mon, Oct 12, 2015 at 6:11:04 PM
Adaptive panel flips sides of divided surface
Sun, Apr 4, 2021 at 1:45:38 PM
Adaptive points gone mad?
Mon, Jan 13, 2020 at 7:04:14 AM
Page generation time: 0.8251
