Forums >> Revit Building >> Technical Support >> Topo cut not changing in plan region.
Tue, Jan 19, 2016 at 10:12:54 AM | Topo cut not changing in plan region.
swdebenport
5 Stars: 3 Votes
I am working on an existing building where the ground is much higher on one side than the other. However there is a drainage area on the high side we would like to show. I have set up a plan region in this area in hopes of setting the cut plane higher (to show the contour lines instead of the cut topo). However changing the cut plane in this plan region does not change the topo cut. Do plan regions not affect topo surfaces, or am I missing something.
Tue, Jan 19, 2016 at 12:13:01 PM | Topo cut not changing in plan region.
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Plan regions won't alter topo
Tue, Jan 19, 2016 at 12:29:35 PM | Topo cut not changing in plan region.
swdebenport
5 Stars: 3 Votes
So the only way to control the cut of a Topo is by changing the cut plane of the entire view?  Seems a bit strange.
Topo
Thu, Sep 4, 2014 at 12:46:42 PM
Plan region not showing lines in detail view [ 1 2 ]
Mon, May 11, 2015 at 11:17:48 AM
15
Plan Regions
Fri, Jun 17, 2016 at 12:50:11 PM
Plan Region problem - walls/slabs/framing displaying outside the region boundary
Tue, Jun 23, 2009 at 4:46:32 PM
Plan Region Oddity?
Thu, Nov 7, 2013 at 9:32:05 AM
Page generation time: 0.5618
