27 Users Online (25 Members):
Forums >> Revit Structure >> Technical Support >> Adjusting footing appearence.
0 Posts No Rating |
Hello, I'm trying to adjust the appearence of my wall footings. (boss wants it to look more like the autocad jobs they did in the past. I was able to adjust the object settings to get a fatter hidden line. But where the footing is technically hidden by a floor, I can't figure out how to adjust the line weight. Any thoughts?
0 Posts No Rating |
Have you tried using the modify linework command? If there aren't lines there that you like, you can create more. If you don't know about either of these commands, let me know and I can tell you. If you do know about them, then that's what I would try to do. Sometimes I make linework invisible using the modify linework tool, then draw over it with detail lines. That isn't very often, and only it certain cases, but it's an option.
1 Posts No Rating |
Why not override the graphics in Visibility/Graphics? Visibility Graphics>Model Categories>Structural Foundations, Under Projection/Surface change Lines to whatever Weight and Pattern you need. This will override any other settings such as Hidden Lines, etc..
Continuous Wall Footing ? |
Thu, Aug 23, 2012 at 1:59:47 PM
13
Foundation Top of Footing (when Level is something other than 0'-0") |
Fri, Jan 29, 2016 at 1:40:13 PM
Top of Isolated Column Footing forced to snap to bottom of column |
Mon, Jan 13, 2014 at 7:41:43 PM
Wall profile footing issure |
Fri, Oct 3, 2014 at 7:06:49 AM
Double footing problem - plz help?? |
Thu, Nov 15, 2012 at 3:24:50 PM
