31 Users Online (29 Members):
Forums >> Revit Structure >> Technical Support >> How To Create A Complex Sweep?
Hey guys, I'm using Revit 2015. I'm including a .png of the object I'm trying to model in Revit. This is a strand loop that we embed into precast pieces and use it to lift the piece for stripping or erection purposes.
I feel like it should be able to be done with the Swept Blend command, but I haven't been able to get it to work. Any ideas? Thanks ahead of time.
Take a look at this similar thread. Hope it helps.
I don't see this as a Sweep Blend. Looks like a simple sweep, ending and sterting with a circle profile.
This is relatively easy to do. Create a path to follow with a Ref. or Model Line, then open the Sweep Command
and pick those lines for the path. Then go to edit profile and sketch your circle. Save and presto! Your Sweep complete.
something like this quickie...
Thanks pijpiwo!
That link you put here was exactly what I needed. Here's an image of basically what I did. Using an extrusion's faces as the reference planes worked like a charm!
...or you could do it the slower way if you're being paid by the hour.
thanks, i did have the same thoughts too.
Complex sweep |
Thu, Mar 14, 2013 at 10:18:30 AM
Complex profile sweep |
Fri, Feb 6, 2009 at 2:08:35 PM
12
Sweep complex coffered ceiling |
Thu, Feb 23, 2012 at 12:03:08 PM
Can't Create Sweep |
Wed, Sep 20, 2006 at 2:39:47 PM
Having problems when trying to create a Steeple using Sweep |
Wed, Apr 28, 2010 at 2:29:19 PM
11
