Forums >> Revit Building >> Technical Support >> Rooms Gross sf
Thu, Jan 14, 2016 at 2:22:14 PM | Rooms Gross sf
lchlimou
Hi! Is there a way to get gross sf for each room? I need the area to be taken from the interior wall centerline and outer edge of exterior wall.
I know how to adjust the area/volume comps, but it seems the only options are to compute room areas from wall finish, wall center, and wall core, wall core center. I don't think any of those help in my case where i need the center of interiors and outer edge of exterior walls (?)
Are area plans my only option here?
Thanks!
Linda
Thu, Jan 14, 2016 at 2:28:30 PM | Rooms Gross sf
When we need this, we turn off room bounding for the exterior walls and add our own room bounding line along the exterior.
Thu, Jan 14, 2016 at 3:05:22 PM | Rooms Gross sf
lchlimou
That sounds like a great idea. I will try that. Thanks!
Gross volume of a building
Wed, Jun 4, 2008 at 1:41:10 AM
Rentable vs Gross area, gross area in practice
Tue, Mar 13, 2012 at 11:15:27 AM
Gross areas & Phasing
Mon, Feb 23, 2015 at 9:14:01 AM
IFC export: Gross Area
Fri, May 29, 2009 at 3:01:19 AM
first time using gross building area - whouldnt my shafts be deducted?
Wed, Mar 26, 2014 at 1:39:28 PM
Page generation time: 2.3889
