Forums >> General Discussion >> Revit Project Management >> Default Sheet Settings
Wed, Jan 13, 2016 at 2:37:04 PM | Default Sheet Settings
revitape
revitape Avatar
4.5 Stars: 9 Votes
Like most places, I set up a clients sheets with a "Discipline" parameter for organization purposes.
Unfortunately when you make a new sheet, it leaves this parameter blank and you have to manually input it.
Is there a way to have this automatically default to the "Architecture" discipline when you create a new sheet?
High quality modern Revit furniture!
www.therevitcollection.com
The Revit Collection: High Quality Revit Families | Revit Furniture
Wed, Jan 13, 2016 at 2:57:06 PM | Default Sheet Settings
Type based...
Thu, Jan 14, 2016 at 10:59:57 AM | Default Sheet Settings
zsmith3
You can do this, but only if the sheet is empty (no view, legends, etc.). Right click the empty sheet in your project browser and click 'Copy to Clipboard'. Hover your mouse back to the project enviornment. Then, on the Modfiy ribbon, collapse Paste and select 'Paste from Clipboard'. It will create a new sheet that retains most of your instance params.
Thu, Jan 14, 2016 at 1:35:09 PM | Default Sheet Settings
marmiketin1
4.5 Stars: 10 Votes
WWHub's answer is the correct one. As long as the discipline is part of the titleblock you can just create a new type of said titleblock and then set defaults for any and all parameters associated with it. It does not matter at all if there are things currently on the sheet. Nothing gets romoved if you change which titleblock you are using.
Thu, Jan 14, 2016 at 9:00:39 PM | Default Sheet Settings
zsmith3
"Correct" is relative. Method posted above is valuable if your workflow requires instance parameters in your sheets.
Thu, Jan 14, 2016 at 9:15:56 PM | Default Sheet Settings
revitape
revitape Avatar
4.5 Stars: 9 Votes
Indeed zsmith. They also already have type parameters for the titleblock so it wouldn't really fit or make sense to create new types that have to do with the disciplines.
Fri, Jan 15, 2016 at 7:31:04 AM | Default Sheet Settings
revitape ... I don't understand "...it wouldn't really fit or make sense to create new types that have to do with the disciplines. ..."  Why?  Types are so easy and they really don'e affect file size.
Fri, Jan 15, 2016 at 8:52:46 AM | Default Sheet Settings
revitape
revitape Avatar
4.5 Stars: 9 Votes
I'm saying we already have types for the titleblocks right now. In this case it would be like having 5 types of apples then you throw 2 oranges in there. It's possible, but not consistent with what we have already.
Fri, Jan 15, 2016 at 1:11:37 PM | Default Sheet Settings
marmiketin1
4.5 Stars: 10 Votes
It would seem to me that you obviously want a 6th type in your sheet family. but if you dont want to do that just go into the current type you are using and open up the family parameters and under discipine put the one you want and that will be the what it defaults too once you have saved the family and loaded it back in.
Also zsmith, you can have both instance and type parameters in the same family. the type parameters will be defined by the type and the instance ones will be free to change to whatever you like no matter what type you are using.
Fri, Jan 15, 2016 at 2:00:54 PM | Default Sheet Settings
zsmith3
Quoting marmiketin1 from 2016-01-15 13:11:37
Please, spare me the Revit 101. Especially if that solution seems like the obvious solution to you.
There's this notion among Revit users that 'everything that can be type-based should be type-based'. I abandoned that untruth long ago. The reason has nothing to do with organization and everything to do with workflow.
Edited on: Fri, Jan 15, 2016 at 2:07:44 PM
default settings - can they be printed out?
Fri, Dec 1, 2006 at 11:40:11 AM
Keynotes filter by sheet and default graphics
Mon, Jan 8, 2018 at 3:40:58 PM
default export to DWG settings
Mon, Jul 2, 2012 at 2:38:13 PM
Where's my default 3D view?
Wed, May 6, 2009 at 9:44:52 AM
Restore Default Materials
Thu, Dec 17, 2009 at 4:51:08 PM
Page generation time: 2.9344
