Forums >> Revit Building >> Technical Support >> Countertop material / view problems
Fri, Jan 8, 2016 at 2:10:25 PM | Countertop material / view problems
kurtf
I'm working with a OOTB countertop, which I duplicated and changed to a new laminate color...from the OOTB ivory to a medium gray.  The color change shows up in 3D views and others, but no matter what I've tried, the plan view appears white.
I attached pdf's of the the plan and a perspective.
Any ideas what I'm doing wrong?
Thank you in advance.
Fri, Jan 8, 2016 at 4:26:22 PM | Countertop material / view problems
kurtf
v2015
Sat, Jan 9, 2016 at 9:17:19 PM | Countertop material / view problems
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
If you change Visual Style to the Consistent Colors in the plan view, does it make any difference?
Mon, Jan 11, 2016 at 10:24:42 AM | Countertop material / view problems
kurtf
^ unfortunately, no.
Mon, Jan 11, 2016 at 11:54:43 AM | Countertop material / view problems
kurtf
Ok.  Many such objects have a mask region.  To myself, I say "duh".
Anyone ever put a countertop on a wall as a sweep? Anyone?
Wed, Nov 15, 2006 at 3:42:51 PM
How do I add a countertop to the Base Cabinet - Corner Unit Angled?
Thu, Mar 30, 2006 at 6:58:55 AM
Countertop Invisibility
Mon, Jan 5, 2009 at 1:46:39 PM
View Range problems- seeing wall detail
Fri, Jun 6, 2008 at 8:56:57 AM
Using formulas to control geometry joining?
Tue, Aug 5, 2014 at 2:54:45 PM
Page generation time: 0.8096
