Forums >> Revit Structure >> Technical Support >> Hilti kwik bolt not rendering properly
Mon, Jan 4, 2016 at 10:38:30 AM | Hilti kwik bolt not rendering properly
pwoolson
Hello,
I'm trying to render a structural connection in Revit 2016. I'm using Hilti's plug to their modeled fasteners. However, when I render the model, the bolts still show the construction lines. Any tips?
Mon, Jan 4, 2016 at 10:42:15 AM | Hilti kwik bolt not rendering properly
You have to look at their settings....  Look under the family category for that element.
Mon, Jan 4, 2016 at 11:06:44 AM | Hilti kwik bolt not rendering properly
pwoolson
Can you walk me through what I'm looking at/for?
Mon, Jan 4, 2016 at 12:42:32 PM | Hilti kwik bolt not rendering properly
I could if I had the family ... but I don't.  It looks like they may be under specialty equipment.
Mon, Jan 4, 2016 at 2:46:49 PM | Hilti kwik bolt not rendering properly
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
This doesn't look like a native revit rfa element. It's a family that has an old DWG block inserted and then saved as an rfa file but it's not actually revit solids. This is comman and a simple way for people to use the old 3D CAD blocks in REVIT. ie: Not going to render.
Hilti Stuff
Wed, Aug 4, 2010 at 3:07:53 PM
u-bolt creating_newbie revit modeler
Mon, Jun 18, 2018 at 10:53:55 AM
Dimensions to baseplate bolts
Mon, Jul 10, 2023 at 3:24:27 AM
ROOF TILES -RENDERING
Wed, Aug 17, 2011 at 1:25:28 AM
Revit 2015 Revit is NOT rendering the image color correctly, it renders it GRAY
Tue, Feb 28, 2017 at 2:00:09 PM
Page generation time: 0.2284
