23 Users Online (21 Members):
Forums >> Revit Building >> Technical Support >> revit topography subregion stretched material
0 Posts No Rating |
In revit 2016, why is this happening?
The picture shows a subregion made from a topography object.
Thank you
/Totte
What is your question? Communicate!
0 Posts No Rating |
Sorry.. Why is the material in the topography subregion stretched out as shown in the attached pictures? It's supposed to be stoned but instead it looks just awful.
I don't see any How can you expect a linear pattern to work on a surface that may not be flat? Look at what happens when I assign a block pattern to a blend round to square. The pattern tries to fit the reducing cone but doesn't know what to do as the square starts to develope.
The answer is - Don't expect revit to work with warped surfaces.
0 Posts No Rating |
Well, if this was a very complex surface I would agree, but there is obviously some error going on here. Look at the grass texture just beside the bugged out texture. Seems nice right? If revit couldn't handle this, the topography wouldn't be material assignable.
Still thankful for any helpful response.
/Totte
I think there's something wonkie with the material appearance settings. I'd start by trying a different 'out of the box' material with a similar style.
I'd also investigate the Material 'Appearance' Settings. See image below.
Subregion material inconsistencies |
Tue, Jul 1, 2008 at 9:49:39 AM
Dang Topo Subregion! |
Wed, Jul 11, 2012 at 2:02:54 AM
Revit Topography schedule - several issues! |
Mon, Jul 14, 2014 at 8:59:00 AM
Material problems Please Help! |
Sat, Apr 21, 2012 at 5:58:38 AM
Material Stretched Horizontally |
Fri, Apr 24, 2015 at 11:45:13 AM
