23 Users Online (21 Members):
Forums >> Revit Building >> Technical Support >> inserting an image in a frame
6 Posts No Rating |
halo!
i need to know how to insert a jpeg or other image into a frame so that when i render it will show and obviously be more realistic!
3 Posts No Rating |
In 3D or in Plans? As background Perhaps?
6 Posts No Rating |
in 3d, plan and ito a picture frame!!
If you are trying to create the effect of a painting on a wall. It can easily be done by creating a family for the piture frame and inserting the image using the decal tool, which you can stretch to the size of your frame. Decals need to be placed an elevation view parallel to the the surface where the image is to be placed. This will allow the image to show in the elevation and 3d views when rendered. The image will not show in the plan however your picture frame may be cut in plan and you can use that as a location for the image.
inserting an image in a frame to render |
Thu, Apr 6, 2006 at 2:15:16 AM
Inserting an image and getting a unusual colour to the image |
Fri, May 30, 2014 at 5:15:25 PM
Doors and Frames |
Thu, Oct 11, 2007 at 11:25:58 AM
inserting image on upper floor |
Thu, Mar 15, 2012 at 9:52:30 AM
Control Position of Door Frame/Panel in Wall Thicker Than Door Frame |
Thu, May 6, 2010 at 7:29:41 AM
