14 Users Online (12 Members):
Forums >> Revit Structure >> Technical Support >> default lighting setting for shadows
0 Posts No Rating |
Hi, does anyone know how to change the default lighting setting for shadows - its set to 50% which is too dark for most printers. I know you can change the settings for each view but that takes forever! Cheers, David (REVIT LT 2015)
Are you using View Templates? If yes, simply make the shadow adjustment in the view template. If no, make a shadow adjustment in the Graphic Display Options (GPO) window in the view properties and Save as View Template - button at the bottom of the GPO. In the project browser, select all views, right click and Apply View Template.
I’ve never worked with LT before, hopefully the above works the same as in the full version.
0 Posts No Rating |
Much appreciated. Thanks
Soft Shadows Revit 2015? |
Thu, Mar 17, 2016 at 5:35:16 AM
SHADOWS WENT LOCO... |
Thu, May 24, 2007 at 5:41:18 PM
Default setting for detail title on inserted drafting views |
Thu, Mar 21, 2013 at 9:41:45 AM
Show Ambient Shadows Greyed Out |
Fri, Jan 18, 2019 at 4:59:23 AM
Would like shadows to appear from above cut plane |
Wed, May 2, 2012 at 1:22:44 PM
