Forums >> Revit Building >> Technical Support >> Accepting Primary Design Option Causes Fatal Error
Tue, Dec 29, 2015 at 2:30:11 PM | Accepting Primary Design Option Causes Fatal Error
palladio1234
5 Stars: 3 Votes
RAGE POST!
That is the last time I use DESIGN OPTIONS in Revit!!!
What is the reason for using it if when you want to accept the option you like the best it causes a fatal error and you cannot continue! OMG so dumb! From now on I will save an individual file for each option.  Gosh that is so annoying.
Tue, Dec 29, 2015 at 3:43:24 PM | Accepting Primary Design Option Causes Fatal Error
We have not seen this problem.  Send to Autodesk because you have something that is corruptrd..
Tue, Dec 29, 2015 at 3:58:30 PM | Accepting Primary Design Option Causes Fatal Error
palladio1234
5 Stars: 3 Votes
Hey wwhub,
I think it is just my file.  We are reusing a building from 2008 and I linked it in and then binded it and did about 4-5 hours worth of design options to it.  When I try to accept the primary option for a certain option set it starts to think and then causes fatal error.  I tried all the usual audits and clean ups but nothing worked for me.  I just went ahead and saved another file and re-modelled all the work for that option we selected.  Just dont have the time to try and figure out what went wrong.  My guess is that somthing went wrong when we used a older 2008 model that was updagreded to 2016 as a link and then binded.
Oh well.  Sorry for the rage post I just had to get it out... Puh
Issue with making a not primary option the primary Design Options Revit 9.0
Wed, Jun 4, 2008 at 5:52:15 PM
Cannot make design option primary
Thu, Jan 6, 2011 at 2:08:04 PM
Mysterious duplicate option sets
Wed, May 2, 2007 at 10:05:19 AM
Design Option " MAKE PRIMARY" Toggle
Mon, Jan 23, 2006 at 9:29:11 AM
Design Option view setting
Fri, May 16, 2014 at 8:02:11 PM
Page generation time: 0.4911
