Forums >> Revit Building >> Technical Support >> Making a template, using another project
Wed, Dec 23, 2015 at 4:57:32 PM | Making a template, using another project
GLKIRK
I am wondering if a person can take a finished project with all the (mostly schedules) entities set up and erase everything and draw a new project and have the (mostly schedules) set up so he can use them without the tedious task of fine tuning them?
Thank you,
Gary
Mon, Jan 4, 2016 at 6:52:09 AM | Making a template, using another project
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Yes. Should be fine. Just note that any 3D objects that populate that schedule and are deleted will be removed from schedules.
It is good BIM management to create project specific templates if you are commonly doing the same project types. And in fact setting them up will save you heaps of time and save your boss heaps of money.
Take a read of this article which provides information on the benefits of creating such templates.
http://www.shoegnome.com/2015/12/09/bim-still-bankrupting-firm/
Mon, Jan 4, 2016 at 4:10:49 PM | Making a template, using another project
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Why not just open the project with all the stuff you want and do a 'saveas' 'templete' to create a new RTE template file ? Voila !
Template to Project
Tue, Jul 31, 2018 at 2:25:32 AM
save new template from project
Tue, Nov 21, 2006 at 7:16:15 PM
Requesting Tips on Making Project Template
Fri, Jan 29, 2010 at 7:57:22 AM
Changing a template to a Project
Tue, Feb 2, 2010 at 7:03:23 AM
Trying to make a template out of a project that had worksharing enabled
Thu, May 28, 2009 at 2:03:53 PM
Page generation time: 7.7824
