Forums >> Revit Building >> Technical Support >> deleting level advice
Mon, Dec 21, 2015 at 2:06:20 PM | deleting level advice
Warchitect
4 Stars: 5 Votes
I have this large 7 story project. there are three separate towers on the property, two of which need to get lowered by 1 level.
So like the image shows, I want to delete the level out of the two larger structures, and leave the smaller center tower alone. Is the best way to do this to delete Level 2, and all the objects on those particular towers, then lower the other levels and rename the levels, (so a level 3 becomes level2)? or is there a smarter way, obviously, all three towers will be affected, but not sure if its better to delete the level, or not.
edit: red arrow is pointing to smaller tower not to be touched.
thanks in advance.
Edited on: Mon, Dec 21, 2015 at 2:06:59 PM
Mon, Dec 21, 2015 at 3:30:10 PM | deleting level advice
I would start with the center tower moving your roof and all levels up one floor.   Then you can remove the elements from that xx'd out level and delete the level.
Mystery of the deleted level tag.
Wed, Aug 20, 2008 at 3:20:54 PM
Move a level without deleting objects on that level
Tue, Jul 4, 2017 at 5:20:23 AM
deleting levels without deleting associated objects on it.
Thu, Aug 1, 2013 at 6:20:35 AM
Deleting levels
Thu, Mar 4, 2010 at 3:06:57 PM
Advice from Professional Architects/Architectural Technicians
Wed, Apr 20, 2016 at 4:47:25 PM
Page generation time: 1.1092
