Forums >> General Discussion >> Revit Project Management >> California building code
Tue, Dec 15, 2015 at 9:15:07 AM | California building code
Larsvanbeek
Hi Everyone, I am currently studying Architecture and started using Revit. For my building project, I need to check whether my design meets the California building code. I know you can do it in excel manually but it takes so long, does anyone know any short cuts I could use?
Tue, Dec 15, 2015 at 10:34:18 AM | California building code
You really have this backwards.   You check the code before you begin and you design to it's limitations.
Wed, Dec 23, 2015 at 8:01:12 AM | California building code
Larsvanbeek
Hi WWHUB,
Thank you for your response. You were right by the way, I asked my teacher. I did find something that helped me make up for my mistake. I found a plug-in for Revit which allowed me to check whether my design met the California building code after I made my design. If you want to check it out, I found it at the autodesk app store. It's called 'Spatial Requirements Assistant' and it was published by Vabi. It says you have to pay for it but if you download it you can just use it for free for one month. Thanks again for your help.
Building code summary?
Mon, Feb 13, 2006 at 2:40:58 PM
Revit MEP Users in California
Tue, Aug 5, 2008 at 1:06:29 AM
Activation Code
Thu, Mar 10, 2011 at 3:25:54 PM
plumbing code
Tue, Jun 12, 2012 at 2:18:31 AM
Building Perimeter
Tue, Oct 3, 2017 at 6:55:38 AM
Page generation time: 0.7503
