12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> symbols in text
29 Posts No Rating |
hey....
I'm sure this has been discussed before, but... how does one insert symbols in lines of text... ie: meters squared... and the degrees symbol....
cheers
Brad
"Use a repeating detail component." Man i must have glazed over that post. Sorry my answer was for something completely different.
Yes as everyone else has suggested use the windows character map.
Post edited on 2006-04-04 17:21:40
you can enter the codes when you type like: alt+178 (on the num pad) will give you square...
not sure about the rest, you'll need to find out
If you're going to use the Alt codes or the Character Map keep in mind that when you export drawings to DWG the text that contains these characters will disappear. I don't think Revit's Export to DWG supports special characters yet.
Post edited on 2006-04-04 11:53:23
Text symbols [ 1 2 ] |
Tue, Mar 10, 2015 at 10:14:14 PM
18
Text Symbols? [ 1 2 ] |
Tue, Apr 28, 2009 at 2:43:34 PM
22
text symbols |
Thu, May 31, 2007 at 3:39:19 PM
The ability of adding text or symbols into line patterns |
Thu, Oct 30, 2014 at 2:45:39 AM
Text Styles |
Tue, Aug 4, 2009 at 9:59:13 AM
