10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Schedule headers disappear
A small but annoying behaviour in revit that has been around for a number of years: when you are working in a schedule and select the bottom line of the schedule, the headers disappear and I can find no way to make them come back with out closing and re-opening the schedule. Here is what I mean... https://goo.gl/u7HrtS Seems to be in style schedules, which one wants to add or edit with some frequency and so that tends to happen in the last line, then you must close and re-open.
Is there a way?
When you say style schedule do you mean a "schedule key"?
I don't have the problem you describe. If my schedule is too tall for the screen, the headers scroll off the top but I just scroll up if I need to see them. Revit does not have a command like excel does to freeze the headers.
It happens in key schedules, not regular schedules ... see video: https://goo.gl/u7HrtS
It only happens when choosing or selecting the last row, which is every time you add a row entry to key schedules. My half a work-around is to create a key called xxxx and try to avoid touching it.
Something else going on there. I have never had this problem and I can't re-create it. It is a corrupted file or your system.
i don't think its a file problem. It's been hapenning for several releases of Revit in every drawing on several different machines, through several upgrades. I tried creating a new schedule key in a brand new blank project from a revit template . Immediately upon creating the schedule key, inserting a couple rows of data, if I select the bottom row the headers dissapear.
Schedule Headers |
Wed, Mar 21, 2012 at 3:42:41 PM
Schedule Headers-bold? |
Wed, Aug 10, 2016 at 3:26:33 AM
Freezing Headers in Schedule - Revit 2014 |
Mon, Jul 1, 2013 at 11:11:36 PM
advanced schedule tabulation |
Thu, Nov 7, 2013 at 3:56:38 AM
Schedule Title Formatting |
Thu, Jan 8, 2009 at 11:12:07 AM
