18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Revit export to DWG, lines and hatches in the same layer (after file upgreade)
Hi,
I open a file (made in revit 2015) in Revit 2016, so it upgreaded to higher version. but there is strange problem,
when I wanna export to dwg (default options) I Get drawing where for example walls ang windows are in same layer and are
in SOLID HATCH!
There is no problem with files, which were started working in Revit 2016 (not upgreaded from older)
p.s. In Revit 2015 everything works perfect. I just wanna emphasis that all options are default in "Modify DWG/DXF Export Setup"
You need to send this to Autodesk.
Export to DWG: distinguish Wall hatches from the inner and outher wall lines |
Wed, Mar 1, 2006 at 8:34:41 AM
EXPOR LAYERS for WALL HATCHES are missing |
Wed, Mar 1, 2006 at 8:30:58 AM
Export to DWF vs. DWG |
Tue, Apr 24, 2012 at 3:52:31 PM
Keep .dwg Layers when exporting .rvt to .dwgPlease |
Wed, Feb 24, 2016 at 9:27:59 AM
Revit Export to 3D .DWG still will not export Ceiling Grid Hatches? |
Wed, Feb 11, 2009 at 4:42:25 PM
