33 Users Online (31 Members):
Forums >> Revit Structure >> Technical Support >> Cope Flange/Beam
0 Posts No Rating |
Hi guys,
I've noticed that this has been a question before but I have a different problem. I want to cope the flange of my lower beam into my higher beam. The first picture shows the high/low beam scenario, the second picture shows what Revit does after the cope tool and the third picture is what I need it to look like. Any suggestions on how I can do this?
Thanks in advance!
Obviously, your needs are not met with the standard cope. Use a face based void family to do your work or a model in place.
0 Posts No Rating |
- Try adjusting the coping values in the properties window.
- If you were to model in place and cut with voids, you would lose a lot of other functionality with the structural tools.
How to extend top flange of beam (over top of column)? |
Fri, Jun 15, 2012 at 10:35:08 AM
Precast Beam System not sitting on beam |
Thu, Jan 10, 2013 at 11:45:48 AM
Beam system not sitting on beam |
Thu, Jan 3, 2013 at 11:40:10 AM
Beam cutbacks in Revit 2014 |
Thu, May 2, 2013 at 7:37:22 AM
How to taper the end of a wide flange beam |
Tue, Mar 17, 2015 at 2:11:51 PM
