Forums >> Revit Building >> Technical Support >> Glass Block Window by Mr. Spot
Mon, Apr 3, 2006 at 5:41:51 PM | Glass Block Window by Mr. Spot
josta
1 Stars: 1 Votes
It's a great family; I see that it is parametric but I can't figure out how to resize it....can anybody point me in the right direction? Thanks! John
John Acosta ARA, Architect
Mountain Architecture, Big Bear Lake CA
Mon, Apr 3, 2006 at 6:42:58 PM | RE: Glass Block Window by Mr. Spot
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
If i remember correctly you resize it by specifying the number of blocks you require. I did it this way as the blocks are a set size and as such it was best to let this define the size. HTH.
Tue, Apr 4, 2006 at 3:11:30 PM | RE: Glass Block Window by Mr. Spot
josta
1 Stars: 1 Votes
Got it....thanks, Mr. Spot! JOHN
Glass Block Wall
Wed, Apr 20, 2005 at 12:04:41 AM
extrusions
Fri, Jan 16, 2004 at 3:33:47 PM
multipanel window with variable sizes
Wed, Apr 20, 2005 at 9:10:11 AM
11
Glass Block Wall
Wed, Feb 23, 2011 at 2:01:24 PM
Glass block
Sun, Jun 4, 2006 at 12:38:25 PM
Page generation time: 1.3790
