Forums >> General Discussion >> Revit Project Management >> Renumbering rooms -- rooms out of numeric order on Room Finish Schedule
Thu, Dec 10, 2015 at 8:16:03 AM | Renumbering rooms -- rooms out of numeric order on Room Finish Schedule
kurtf
New to Revit, was sailing along pretty well and ran into an issue.  The room numbers on my Room Finish Schedule are out of order.  I'm using 2105 out-of-the-box, no additional renumbering tools added on at this time.
I have renumbered the room on the plan a couple of times -- click tag, change number, next -- did I do this wrong?
I've read that Revit should automatically renumber the room in order on the Room Finish Schedule...?  Mine does not seem to be doing so.
Thanks in advance for any help.
Kurt
Thu, Dec 10, 2015 at 10:26:07 AM | Renumbering rooms -- rooms out of numeric order on Room Finish Schedule
The room finish schedule always reads exactly the rooms you have placed.   I think your problem is the sequence you see in the schedule - correct.  The ordering of the schedule is depended on your schedule setup.   If your sort is by room number, then they will be sorted by number.  You can have multiple sort priorities.
Thu, Dec 10, 2015 at 11:01:57 AM | Renumbering rooms -- rooms out of numeric order on Room Finish Schedule
kurtf
WWhub:  Wow.  That was easy.  You were exactly right -- click FIELDS, then SORTING/GROUPING.  Thank you!  -- Kurt
Room finish Schedule showing Deleted Rooms
Wed, Aug 26, 2009 at 3:56:37 PM
Imported 2D Cad drawings > Rooms and Room tags possible?
Fri, Jul 1, 2011 at 1:07:42 PM
Rooms not showing up in room schedule, please help
Sat, Oct 27, 2012 at 10:52:34 AM
Finish Schedule Duplicate Rooms - Revit 2010
Mon, Mar 5, 2018 at 6:34:50 PM
Deleting Rooms
Sun, Aug 26, 2012 at 8:47:46 PM
Page generation time: 0.7426
