11 Users Online (9 Members):
Forums >> General Discussion >> Revit Project Management >> Re-use duplicated objects/settings across multiple projects
Hi everyone.
I'm doing a huge complex, concisting of 18 buildings. To keep it a little bit more simple to navigate (and less data-heavy!), I've decided to make 18 seperate files with one for each building, and then have one file where they are all linked into.
However, here comes my question. With all the tons of different materials/settings/duplications of walls/windows/etc I did in the first project, I'd love to be able to copy all of those settings to the other projects as well, so I don't have to manually make them all, over and over again.
Does any of you know of a way to do this?
Kind Regards,
Sebastian
You can problably solved in 2 ways. Either by using transfer project standards, or using your original file as a template.
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
"Transfer Project Standards" worked flawlessly. Thank you very much .
Have a nice day.
Room Schedule - Multiple Room References |
Sat, Dec 5, 2009 at 4:34:02 PM
Multiple Projects/Phases within Master Central File |
Thu, Apr 26, 2012 at 8:43:55 PM
13
Rendering with objects downloaded from revitcity |
Tue, Feb 27, 2007 at 2:34:24 PM
Two projects |
Tue, Mar 1, 2011 at 12:29:28 PM
adding material to a dxf object |
Tue, Nov 8, 2005 at 6:59:00 AM
